Sold F/S BNIB Sundown Saz-2500d w/toolmaker terminals
power-fanatic07
Knockin Doors Down
The SAZ-2500D replaces the SAZ-2000D in our line-up. It packs 25% more power into a casing only 3/4" longer than the older SAZ-2000D model. The 2500D features an output section equal to our highly regarded SAZ-3000D model and an extremely robust power supply section to back it up!
All of the latest technology and R&D available to us was implemented in the 2500D -- years of experience in the SPL lanes and in customer vehicles has all been taken into account. We feel that the 2500D is a very worthy addition to our line up for both hardcore SPL competitors and enthusiasts alike.
We do highly recommend a high output alternator and additional battery for this model.
SPECIFICATIONS:
•Digital Class-D Linkable Mono Block Amplifier
•Double Sided Through Hole Epoxy PCB
•1 Ohm Stability
•Daisy-Chain Through Output RCA
•Efficiency : 86% @ 4 ohm, at 100Hz
•24dB/Oct Variable Crossover
•Multi-Way Protection Circuitry
•(Thermal/Over Current/Speaker Short/Speaker DC Protection)
•RCA Line Input and Master Output
•24dB Octave Crossover Slope
•24dB Octave Variable Subsonic Crossover Slope
•Variable Bass Boost
•Variable Low Pass Filter
•Variable Phase Shift
•Zero(0) Gauge Power Supply Connectors
•Tested Voltage & THD : 14.4V & Less than 1% THD
•Operating Voltage : DC 10V~18V
•Wired Remote Controller
•MSRP $1299 USD
Ratings :
2500 @ 1 ohm
1200 @ 2 ohms
600 @ 4 ohms
Jacobs Testing :
Wired @ 1 ohm :
1690 Watts
21.4 Amps
78.97 Volts
3.69 ohms Actual
Wired @ 0.25 :
3360 Watts
63 Amps
53 Volts
0.85 ohm actual
Around 14v actual voltage
475 Shipped and Insured -- No Trades
This is BNIB. Never used, never installed. Comes with everything as if you bought it brand new. 2 year transferable warranty. Toolmaker dual 1/0 terminals for +/- with extra spot for volt meter.
If you need more pics or info just ask. Will be shipped via UPS with insurance.
This is a bomb a** deal man I wish I had the cash. I have about 375 saved so far and if I get my amp sold then I will deff hit you up man this would power my 18 great ill keep you posted man.
power-fanatic07
Knockin Doors Down
power-fanatic07
Texas
bubbagumper6
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
