F/S Audiobahn A8000t class A/B Monoblock 800W rms@ 2ohms = Cheap!
ampjunkielikeme
Item(s) for Sale: used audiobahn a8000t
the amp has been fully tested and it works great. ( i rebuilt the power supply on this one) i also put 2 40 amp fuses in it.( came with 2 30's).. it's all i had on hand..
this is made to run a sub. it's a 1 channel monoblock amplifier...i like that it lights up blue everywhere...lol.. audiobling FTW!....
it has scratches and scuffs. but nothing that hurts the performance...
this amp is made pretty good. it uses Sanken transistors for outputs. (those are expensive if you can find them) if you can get past the chrome and led lights. it is a decent amp...
if i were to use it... i would hook it up to a single sundown sa8v2 d4 and let it wang.
specs:
•400 watts RMS x 1 at 4 ohms
•800 watts RMS x 1 at 2 ohms
•MOSFET power supply
•two 30-amp fuses
•50-120 Hz low-pass crossover, 18 dB/octave
•variable bass boost (0-18 dB at 50 Hz)
•preamp outputs
•1 cooling fan
•cobalt blue illumination
•speaker- and preamp-level inputs
•4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•11-5/16"W x 2-5/8"H x 13-1/4"D
$58.00 shipped to the cont usa.... no trades..
* below was copied from crutchfield.com*
If you want Audiobahn performance in a smaller package, check out the Intake series amps! A built-in air intake and a cooling fan ensures that these compact workhorses will stay cool through hours of heavy use. The A8000T pumps out 400 watts RMS of MOSFET-fueled Class AB power to your 4-ohm subwoofer. Hook up a 2-ohm load, and you get twice the output!
You get the precise sonic control that you expect from Audiobahn. A variable low-pass crossover trims unwanted frequencies, so your lows are clean and clear. You can improve the efficiency of your speaker system by adjusting the subsonic filter (variable from 20 to 50 Hz) to block ultra-low frequencies that your subs can't reproduce. Dial in the bass boost to bring on a bass-quake!
**** the outputs alone probably are worth the asking price. I have a little audiobling amp here that is a serious performer if you can get past the chrome and lights. They actually did make some ok stuff.
ampjunkielikeme
ampjunkielikeme
nash, tn
KillerQ
