F/S 2 Old School Nakamichi 10's BNIB ....
Louisiana_CRX
dem shoes......
2 Brand New Nakamichi 10" subwoofers
These are brand new so never used or abused...I bought these for a project back in the day and never used them. These are designed for compact sealed enclousures similar to the original round Kicker Solobarics...They need .66 cu ft each. Also these are fairly shallow mount...So great for single cab trucks or other small vehicles where space is a premium...about 5"s ...I could measure and get exact depth if needed....these are single voice coil 4 ohm 300watt subs
$180.00 shipped for the pair CONUS
wtf is on the surround
If you mean gasket I think that is supposed to be like an arctic camo design lol
EDIT: just realized the sub doesn't have a gasket and that is the surround... //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
thats on the cork gasket they came that way from the factory...its molded in to the material...Cadence had a sub like that years ago so probably the same build house...these are US made subs..the Cadence one i had was blue not white though....i need to dig it out and compare these in design...the Cadence still works..after years of brutal abuse ..but the terminal block broke so i stored it away someplace
Do u have tech specs
SUBWOOFER SPECIFICATIONS
Diameter: 10"
254mm
Sensitivity: 88.7dB
Power Handling:
Watts RMS: 250 Watts
Watts Peak: 400 Watts
Frequency Response: 25Hz-500Hz
Nominal Impedance: 4 Ohms
Cone Material: Polypropylene
Basket Material: Steel
Surround Material: 2" Rubber
Spider Material: Poly/Cotton
Magnet Weight: 100oz.
Voice Coil: Single
Free-Air Resonance (Fs): 25.612Hz
Mechanical Dampening (Qms): 4.409
Electrical Dampening (Qes): .335
Total System Dampening (Qts): .312
Voice Coil DC Resistance (Re): 3.2 Ohms
Equivalent Acoustic Volume (Vas): 75.656 Liters
Effective Diaphragm Area (Sd): 33.006 sq. meter
Linear Coil Excursion (Xmax): 10.5mm
Half Space Output Level (SPL): 88.7dB
Energy Bandwidth Product (EBP): 76.45
Mass of the Moving System (Mms): 79.163 grams
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
