Sold f/s 2 12"pioneer premeirs
TS-W1241C :
Brand Pioneer
Manufacturer Part Number ts-w1241dvc
Nominal Power Handling Over 300 W
Surround Material Urethane
Nominal Power Handling 500 Watt
Size 12"
Power Handling 1000W (Peak), 500W (RMS)
Technical Features
Frequency Respond 15 Hz - 20,000 Hz
Impedance 8 ohm
Peak Power Handling 1000 Watt
Sensitivity 89 dB
More Information
Being a 1000-Watt Premier subwoofer, the TS-W1241DVC features the latest design and materials to produce stunning power and precision. This model includes a dual voice coil protected by VCCS, so you can run it at hideously high levels for hours with lower distortion. The woofer is Nickel-Coated Foamed IMPP, whose lightweight yet rigid properties truly improve sound quality. This sub's design allows installation in a small sealed box, if desired. Get ready to totally transform your mobile entertainment system.
...Sensativity = 88dB
...Freq Resp = 15 - 2,000
...Mag Wt. = 50 oz
...Displacement = .11 cu ft (3.11 liters)
...Recv = 3.0
...Levc (mH) (4 ohm) = 2.59
...Zmax (4 ohm) = 102.6
...Fs = 20
...Qms = 9.48
...Qes = 0.30
...Qts = 0.29
...Vas = 4.18 cu ft (118 liters)
...Rms (N*S/m) = 2.5
...Mms (g) = 186
...Cms(m/N) = 3.36x10^-4
...Diam (inch) = 9.9 (mm) 251
...Sd (sq in) = 76.8 (sq.m) 0.0495
...BL (T*m) (4 ohm) = 15.78
...Xmax (inch) = .36 (mm) 9.2
...Hvc (inch) = 1.20 (mm) 30.4
...Hag (inch) = 0.47 (mm) 12
Sleeklsc
Sleeklsc
Sleeklsc
