2002 F-Body Rear Hump Sealed Enclosure for 2 12" subwoofers
Dimensions:
Length: 36" Width: 14.625"" Height Front: 11.75" Height Rear: 9.75"
Mounting Hole: 11.1" dia
CuFt Per sub: 1.2cuft
Condition and info:
The reason that i built this was to run two twelve's and at the same time leave the t-top well area Free for storage and t-tops storage. I overbuilt this box, as you can see in the photos everything is screwed, glued, and siliconed. The box has an angled top that follows that back window. Also there is a black cloth cover that covers the subs. The carpeting is black. I cant fully remember if I carpeted the center bottom of this box. This doesn't make a difference since its the bottom of the box, but I just wanted to make the buyer aware of it. The box is also equipped with terminal cups as you can see in the 8th photo down. To fasten the box to the car there is a 1/4" hole in the bottom of each chamber of this box that I used to bolt down into the stock "tie downs brackets holes" on the rear well hump. If you do not wish to use these, that wont be a problem you can just seal them up with a little silicone, or resin. This box does NOT obstruct with your line of sight through the rear view mirror. In my rear view mirror I can still completely see under the rear wing of my TA. I have tried to demonstrate with the last picture on the list below.
Price: 112 + Shipping
Shipping info: Contact me with you zipcode, and if you would like to have insurance (and how much) on this item. I will get back to you with the actual shipping cost. No bloat!
Pictures:
Picture 01
Picture 02
Picture 03
Picture 04
Picture 05
Picture 06
Picture 07
Picture 08
Picture 09
Bumps are welcome!
Dimensions:
Condition and info:
Pictures:
Picture 01
Picture 02
Picture 03
Picture 04
Picture 05
Picture 06
Picture 07
Picture 08
Picture 09
Bumps are welcome!
