Extra mounting holes in the subwoofer basket
Hm, I'm looking at the T-nuts and can't figure out how they work... Where does the nut with the teeth go? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
it goes on the inside of the box. bites into the wood from the back.
ill probably pass on the T nuts, dont want a gaping hole if something happens to it. i may just drill 2 extra holes in between the bottom 3 stock mounting holes to provide extra support. like someone said above, thats where the most stress will be with the weight trying to push out on the screws
what are some heavier duty screws out there? ill pre-drill the holes
commonly available at HD or Lowes are deck screws, they are much stronger than drywall screws
What would be interesting is for someone to make a ring that is 1/2" thich with threaded holes that match the woofer's mounting holes. That way the sub would be completely secure distributing the weight more evenly across the mounting surface
i always use coarse threaded stainless steel sheet metal screws. But i also would use common sense and have more than on board to mount too. function first noob, then make it pretty. Who cares how nice it looks when the basket cracks and it laying on the floor becuase you could afford to loose .2 cubes.
I had a coworker do that for me on a box for a couple of 15" RF Power series back in 93 or 94. He made the rings out of 1/8" aluminum and anodized them for me. Used either #10 or 1/4" bolts- I can't remember. Between the woofer mounting holes were some smaller holes to put some little drywall screws from the inside of the enclosure to keep the ring from coming loose while mounting/unmounting the driver. It was sweet.
01 S 10
LOUD
01 S 10
Central Florida
Kil4Thril
