extended cab sub/port position
  • 4
I know this has been discussed many times but here it goes again. I gave a 98 k1500 with a 18" HCCA PSI sub in a box that's 8.75 cubes tuned at 32Hz. Im pulling the back seat out tomorrow. Now I can't decide. Sub up and port forward at the bottom of the seats or sub forward port up? Will it make that much difference? I just don't want to kill any sound by doing port under. It would fit more snug sub up which I like the idea of better. Less could damage the sub that way. Anyway, thanks for reading.
Whoops never saw your reply. Didnt care for sub forward port up very much. I was good but the box didn't fit well. I'm doing port rear sub up right now. I like it pretty good. I may try port forward. Dunno yet
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
sanguine79
Carthage, NC
sanguine79
    May 31, 2024
    May 24, 2024
