EXT Cab 2011 GMC Sierra / SI BM MK's
Jrobison918
I'm really looking into the SI's BM MK line. I would like to run 4 sealed under the backseat, but am not sure if there would be enough room to do this cleanly. I would need 2 cubic ft to do this as they require .5 each. I think 2 cubes is about the max of what you can squeeze out of this area. Does anyone have any ideas/suggestions/words of wisdom in this area?
you're correct that 2 cubes is about the max, without raising the seat or intruding on space.
the si bm mk iv's (you are talking about the shallows?) dont require a lot of airspace so 2 cubes would probably be enough. as you said, it would need to be sealed. I'm uncertain if you could fit 4 12s, due to the hump. You may be able to fit 4 10s or 2 12s though.
do not buy a prefab sealed box. they leak.
I'm looking into the mk3, 4 or 5's depending on which I can find a deal on first. The hump is what concerns me. & no prefab. It will be a custom sealed giving each 12 one half cube. POssibly with some filler.
didnt realize those mk v's are out, **** those look nice. as long as you give them near the right airspace itll be fine because the box is sealed.
Jrobison918
Jrobison918
Oklahoma
Jrobison918
