Expert And Amateur Advice Requested
  • Thread starter AzNTuPaC
  • Start date
  • Replies 6
  • Views 1K
A
AzNTuPaC
Guest
Your opinions on the best amp mono and 4 channel for 500-600 dollars
4 Boston Pros (6.5 System)
Subs (undecided, suggestions would be appreciated, if it works with the amp recommended that would be even better =p)
the jbl 1200.1 is a sweet amp. as for a multi chanel i would go with somthin like ppi or rf they aint o bad but i never really needed a ulti channel amp so im just guessin on these
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Thanks for your help
Just wondering, ive asked another forum, and they recommended an eclipse multi channel for my speakers and a ppi for my sub (whatever sub that is)? Wutcha think? ^^
Thanx again
az ntupac--- check out kickers kx 1200.1
go with the ppi amp for your boston pro 6.5
check out there powerclass (pcx 440 or
pcx 480)//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
kicker, fosgate, memphis, phoenix gold, orion, and ppi are good amps to run ur subs with.
ppi or alpine would be a good amp to run ur components with. i wouldnt run my components with a fosgate, but any of the other above should do the job too, (even the fosgate if you'd like).
these are just the first few that pop into my head, go out and listen to them urself and see what u like.
Find a shop that carries the same components that you own and ask to listen to different amps with those components. Take in your music and insist to the salesjerk that you want to chance tracks, volume, whatever. Do that off and on for a week or two and get a sense of the different sounds of the different amps. There are plenty of good amps out there...find the one that your ears like! Then do the same for subs. I reccomend staying with the same manufacturer of amp for both highs and subs...so once you get your amp for your highs, look at the same manufacturer and listen to different subs in your price range. Check out vehicles in your area that you both like and dislike to help you. Have fun, but don't buy based on cosmetics or what your friends happen to own...trust your ears...
Sounds like me ...i should saved all those yanked Bose amps ithrew in the trash ..i couldve retired off ebay from them now .....lol
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
347
It also lowers the amps efficiency and raises the current draw.
438
598
Guest
IASCA pro 301-6
    May 16, 2024
    May 16, 2024
