This is a first generation 12" Shiva-x from Exodus. It has very little use and is taking up space.
$150.00 plus actual shipping.
FEATURES
* Ultra low distortion XBL^2 motor optimized for low inductance & flat BL curve.
* Massive amounts of linear excursion (27mm x-max one-way) for high output and low distortion.
* Extremely high quality parts selection. Excellent build quality and design by one of the world's experts on low frequency transducer design.
* Dual 8 Ohm Voice-Coil arrangement for multiple hook-up arrangements.
* Spring loaded terminals for easy hookup.
SPECIFICATIONS
* Fs: 20.0 Hz
* Le: 0.90mH
* Re: 3.65 Ohms (Voice Coils wired in parallel)
* Qms: 3.20
* Qes: .55
* Qts: 0.47
* Mms: 171g
* Cms: 0.38 mm/N
* Vas: 125L
* Sd: 491 cm^2
* Vd: 2.65L
* BL: 11.9
* X-max: 27mm
* Pmax: 600W
* SPL: 84.4 db/1W/1M
FEATURES
SPECIFICATIONS
* Fs: 20.0 Hz
* Le: 0.90mH
* Qms: 3.20
* Qes: .55
* Qts: 0.47
* Mms: 171g
* Cms: 0.38 mm/N
* Vas: 125L
* Sd: 491 cm^2
* Vd: 2.65L
* BL: 11.9
* X-max: 27mm
* Pmax: 600W
