everyone likes papermaker
The sub I have isnt very efficent like 87db 1w1m. Its really designed with low distortion in mind im sure you could smoke me..
pretty sure im on double the power with a more efficient setup inside an ext cab so yeah
it doesnt meter that great the port is on the pass side, but its still pretty brutal. i could probably get another 3db if i optimized the enclosure and placement.
i doubt the team aa is much more sensitive it's a 4 inch coil, but 4 layer i think
coil smoil. 3" coil with 370 grams of MMS. yuck but i swear its probably the best sounding woofer i've heard ported and its in 4.2 tuned to 34. I'm sure i can pull a 144 or so. its begging for a 5kw. it just needs a slightly larger box and more port area to shine in SPL. 58in^2 is WAY to small.
5k on a 3 inch coil? are you retarded
THE COILS RE are 2ohm so after rise yea. This coil is over 80mm long.. its similar to SD nightshade. granted the NS has abit better cooling i clip my 3600 hard on some stuff no sweat. gotta be mindful on some stuff but a 3500 with 10%THD is more heat the a 5k clean..
i dont see 5k rms going through that coil for long
not 5kw buddy. its closer to about 4k at lowest impedance. yes that it very limit probabl abit more but i know for a fact if i can clip a 3600 with good voltage (about 2400-2600) these specific amp are know for there dynamic power and putting out much more power under a heavy clip.. If i have to put out my meters to measure for you ill do that. Id be conservative and guess 3100@10%THD) or about 4kw @10% thd. i can smoke my 300 amp breaker on music much less tones. i think if im very careful and designed the box correctly its do able.
wew lad
wew lad inc
wew lad
VA
Slo_Ride
