Ever install Line Out Converter??
Mr.SoloDolo
post here if you have.
I have a question
I'm only getting signal from one side of the 2channel RCA.
Is this normal? If I change the 2 gain adjustments to max then it seems to cancel out all signal so the only way to run it for this particular setup is to have one gain all the way up and one gain all the way down. wtf?
If would make sure that you have both + / - from each set of speaker wires, wired correctly into the line out converter. If you don't have both sets wired in correctly, you might be only feeding it 1 channel......giving you only 1 channel of the RCA working.
If its all wired correctly, and you get sound out of both sets of +/- wires (with a test speaker hooked up), then the line out converter is burned out and you need and new one. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If would make sure that you have both + / - from each set of speaker wires, wired correctly into the line out converter. If you don't have both sets wired in correctly, you might be only feeding it 1 channel......giving you only 1 channel of the RCA working. If its all wired correctly, and you get sound out of both sets of +/- wires (with a test speaker hooked up), then the line out converter is burned out and you need and new one. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I'll give checking the wires a try, thanks
may be a bad rca or your the wires you taped into are bad or the wrong wires or the LOC is bad on one channel. What vehicle?
Friends 06' honda accord. I was checking his gains when I realized only one side of the RCA was working and adjusting the gains wasn't helping any.
Mr.SoloDolo
Mr.SoloDolo
Marin County, Ca
Mr.SoloDolo
