Error 2... Help me before I smash my stero into smitherines...
Please can anyone help? My last stereo (sony) had this message so got a new cheap one and it says the same thing when trying to play a CD, the radio works on all three clicks of the ignition BUT the CD player will work only on the second click and even then it's touch and go. I'm seriously peeved so please can anyone offer any advice as I'm a numbskull in such matters..//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
well i have to possible ideas to try. first i would make sure the proper power is being supplied to the deck. check the wiring diagram for your vehicle to make sure you are using the proper acc and constant power supply. next i would make sure you have a good solid ground running to the deck also. if those dont work id check the manufacturers websites for the errors you are having on your deck. hope ive helped.
Trixyminx
Trixyminx
Walton on Thames
Twista89
