EQ help running selenium speakers and tweeters
SWFL
I am wanting to try out some selenium, B&C, or eminence speakers along with some selenium tweeters or other good loud speakers. I need something that will keep up with 4 15's and around 4-5 watts daily. I was wondering since i have always ran passive what kind of equalizer or HU do I need to run a setup with PA drivers and tweeters. I wanted to run either 2 6's per door or a 8 and a 6. along with a tweeter per door. Might do kicks as well.
for power i have a 850.4
If you have any suggestions please post.
Thanks
any eq >7 band will help alot. as far as h/u you can use any as you keep the settings flat on it. all adjustments will be done on amp and eq. i'm doing something of the like. everyone will find out once i'm done.
I got all that, I am saying my amp is capable of running active as far as bandpass so how would i set all that so the mid is playing from 150hz to 4khz and the tweeter is playing from 4k up or w/e the best points that sound the best are.
Not sure if it will do what I need it to do, I have a 7 band graphic eq should i look into a 5or 7 band parametric eq?
Id get these 4 ohm Eminence... Then run 2 per channel, with each channel @ 2 ohms. 2 6s per door, front and back would get loud. Perfect for the 850.4.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-399
For tweeters, a good cheap tweeter is the Eminence APT tweeter. 4 of them total, 1 with each pair of 6s would be great.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-532
Bridge this amp on them.
http://onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19217
Dont know why I posted this as there will be 10 more threads about it.
I dont think I will need anything in the rears if so i will just run off the HU power
those tweeters are huge, what could i run with PA drivers to keep up but not so big would smaller dome tweeters keep up?
Id definately run something in the rears...
Another option would be just bridge the Kicker amp on 4 Eminence Beta 8s, 2 in each front door. Then get another Kicker amp and run a couple sets of coaxials. Run a couple sets in the front doors and a set in the rear doors just to get some noise back there.
The tweeter on the coax would be great because it wouldnt take any room and would be much better sounding on all types of music than any kind of pro audio tweeter.
yea i figured throw something in the rears running what I am going to be running.
I am looking at some vifa or seas tweeters to match with the eminence mids. How would that work out.
Far as an eq what do you think for that.
Also looking at B&C mids you told me about they do look nice
SWFL
SWFL
us
SWFL
