spl_robb 10+ year member Member 124 0 SD Feb 4, 2010 #1 does any one know by how many db's is the epic160 off from an actual termlab meter? have heard that its off by 1-3 db's Click to read more...
Jh8909 10+ year member CarAudio.com Veteran 2,431 35 Pine Hill, NJ Feb 4, 2010 #2 your spot on 1-3. most ive seen in person is 1 off. never seen 3 db's off with the 160.
B basebalz13 10+ year member D-money 4,254 4 roanoke, virginia Feb 4, 2010 #3 sorta depends on what hz, IIRC its more acurate teh higher the HZ is, but the lows gets rather apart from the TL
Jh8909 10+ year member CarAudio.com Veteran 2,431 35 Pine Hill, NJ Feb 4, 2010 #4 also depends on where placement is in the vehicle.
Cabin_Pressure 10+ year member yeah, it'll do 3,216 78 USA Feb 5, 2010 #5 This^^^^^^^^^^^^^^^ Unless you have a 160 mounted to your passenger-side windshield, there's no good way to tell how far off it reads from the TL.
BassAddictJ 5,000+ posts CarAudio.com Veteran 13,568 23 FL Feb 5, 2010 #6 generally 1-3 db off. LOTS of variables come into play.
