Did you do all four doors mat and foam, or did you do them all with mat and then come back later and do the foam? Curious to know if you are describing the difference between sound deadening and no sound deadening or the difference between deadened doors with and without foam.I recently did all four doors in my 01' Maxima. Even my wife noted the difference in road noise as well as an increased level of midbass from the doors. I would recommend it 100% particularly when being layered.
It does neither.The ensolite will be better at blocking/absorbing road noise that is trying to enter the cabin than is the raamat. The ensolite should be installed strategically, like over wheelwells and such.
Good rough guide. But the main 5 factors that make or break an effective absorber are...When it comes to absorbing sound, you need a material that 1/4 as thick as the wave is long. A 1/8" thick material like Ensolite will only absorb ~ 27 kHz and above. 1/4" gets you to ~ 13.5 kHz and above - helpful, but not spectacular.
I was thinking you'd appreciated it.Very informative post.
and which explanation do you think is going to help people decide which products to use in their project? CCF sheeting like Ensolite, Overkill and VB-5 are extremely useful, just not for what people may think (barrier/absorber) and certainly not just for boat cushions.Good rough guide. But the main 5 factors that make or break an effective absorber are...- angle of incidence
- thickness
- flow resistance in the cells/matrix
- depth of cavity
- beginning frequency
Absorption performance goes down as you get closer and closer to the noise source. This is because the particle velocity is lower/slower. If you want to absorb sound, you have to convert it to heat. How well can a product that has poor porosity and no open cells do such a thing? Let alone RIGHT NEXT to the noise source??
Ensolite does make for a super awesome boat cushion, though! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ok, lets go though 5 effective applications for CCF in an automobile if science tells us that CCF is lousy at absorption and refraction.and which explanation do you think is going to help people decide which products to use in their project? CCF sheeting like Ensolite, Overkill and VB-5 are extremely useful, just not for what people may think (barrier/absorber) and certainly not just for boat cushions.
1 and 3 are big deals.Ok, lets go though 5 effective applications for CCF in an automobile if science tells us that CCF is lousy at absorption and refraction.
1) Spring mass barrier/double wall barriers
2) Thermal apps
3) Mechanical isolation of two surfaces
4) Driver decoupling
5) Impact absorber for your trunk or heavy traffic areas.
Copy, paste and add to list....
