enough room for two SA-8's ported? will pay for design
so do you guys think i have enough space for these two 8's or should i do something different? if a saz1200 is too much i can just run it at 2ohms. if these wont sound good with the space im trying to use ill need to rethink my setup. i havent bought anything yet so if you guys think i can get better bass with these dimensions with something different id love to hear your ideas.
Yea as mentioned before, tuning will be hard with the dimensions u got.. Power is not an issue.. they will take more power, they are little beasts. if not u can always do a single sa-10
i did some more measuring in my trunk and i have less room than i thought. i have 29'' width x 18'' deep x 9.5'' height using 3/4'' wood ill have 2.1 cubes to work with //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i had to cut down on the width because the trunk torsion bars come down and are in the way. there will be a lot of room on each side of the box for ports though. maybe i could have ports sticking out the side and they can stick out 8'' on each side and maybe have a 90 degree elbow to make them point up.
you can easily do 2 sa8s.and for you people saying they cant take more than rated in a bigger box, im running a clean 2k to 2 of them in a 1.6 cube box. they like it, so kindly stfu.
they do lack in the suspention department when in bigger boxes, if you do a tone at 30hz on 2k they will not like it in a bigger than normal box
I honestly doubt it sounds as clean as it should, for that much power you should use a smaller box to compensate for move mechanical movement.
1.6 ft^3 would be perfect for a SAZ-1200D @ 1 ohm. With a single 4" aero
I suggest a single sa8 or maybe even a sa10.....I would have to see what the port displacement would be to be for sure which would be better. You could also do sealed if you wanted.
Yea, but haveing 2.1 before any displacement will wind up fairly small. I have yet to check it out to see how small, but I'm sure it is to small for a set.
Yeah, it wouldn't leave enough room to use a properly sized port, unless he wanted to tune higher...like 35hz. I was just commenting on the box size for a pair of SA8's.
3onthree
3onthree
Columbus, OH
RAM_Designs
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
