jurmongler
i have one quantum 12 inch 250 rms 500 watt, and 1 american pro 12 inch sub 250 rms 500 watt dual voice coil. will a quantum 220x2, 440x1 amp power these and how to wire them sequence or parallel?
No.You can't run 2 different subs, they will cancel each other out
everything this guys said is wrong.You can't run 2 different subs, they will cancel each other out. Sell 1 of them. 440 watts will power 2 250watt subs no problem. You could even run 3 of them.
1. No. Again. It is not the same at all whatsoever. Whoever told you that doesn't know anything about speakers.1. Using 2 different subs is same as being out of phase. 2. If you have 3 dual 4 ohm subs you can wire them so the amp sees 4 ohms. Need 1 ohm stability?
My reference 500 is on ebay right now. Rated @12 volts -500 watts(rms) into any load down to 1/2 ohm stereo or 1ohm mono. Dual descrete class A drive stages. Power supply is unregulated- way more power at 13-14 volts. AUction ends in 14 hours.
If they're wired in phase they will be in phase, if wired out of phase then they will be out of phase, it has nothing to do with the brand or model.2 different subs mounted side by side are not working together to produce 1 sound wave. They are producing 2 different sound waves that will interfere with each other. They are not in phase...........
Please go to http://www.bcae1.com and learn something before telling people what you think is right.Running 2 different subs is wrong! Running 2 identical subs is right. And running 3 identical is very right
