Hi all.......//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
here's what the UK has just released into the world, via our very own car audio brand...''Vibe''
this subwoofer is the big brother to the Vibe 'Black Death' sub....
its called the Black Death Bubonic.
here's the specs....
thing looks like a fking monster...... very unexpected from the underdog that is ''Vibe'' //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Basket: VIBE alloy angular torsion basket w/ black epoxy powder coating and CNC detailing
Gasket: Cast aluminium with CNC detail
Magnet: Triple stack 540oz high intensity grade ferrite ring
Motor: Heavy stamp and precise CNC machine top & back plate
Cooling: Magnetic pole 4pcs pie cut ventilation to lower reactance and distortion
Cone: Custom FEA reinforced structured semi-pressed paper composite cone
Surround: Triple-roll cloth surround
Spider: Dual 4 threaded Conex damper with woven round tinsel lead wire
Voice coil: 4” quad 1 ohm voice coil on aluminium former with reinforce neck joint and flat aluminium wire
Dust cap: Poly-glass black hole dustcap which increases effective surface area (SD) and provides forced cooling of the voice coil
NomZ = 1 / 1 + 1 / 1 Ohm
Sd = 0.0825 sqM
Revc = 1 Ohm
Levc = 0.51 mH
BL = 20.5 TxM
Vas = 97.62 Liter
Cms = 101 uM/N
Mms = 482.62 Grams
Fo = 22.8 Hz
Qms = 9
Qes = 0.164
Qts = 0.161
no = 0.682%
SPL@1W = 90.35 dB
SPL@2.83V = 100.1 dB
Xmax/Over Hang = 30mm
Xmech/Suspension = 35mm
Continuous Power = 6,500 Watts RMS
SPL Power = 20,000 Watts RMS
