Engine Noise
Those noise filters are not the way to solve your alternator whine problem. Fix your ground, try a different set of rca's, re-ground your head-unit to the bare metal of the chassis.
quaker is right on the money here.
The noise filters and ground loop isolators are nothing more than a band-aid to cover the problem rather than a cure to eliminate it.
Alternator whine is almost always indicative of a poor ground somewhere in the signal path. It is up to you to troubleshoot just where in the path that bad ground connection is and then remedy it. Could be a bad ground on the HU. Could be a bad set (or sets) of interconnects allowing induced noise into the signal. Could be a poor ground on the amp. It could be all of the afore-mentioned problems.
Find it. Fix it. Done. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah but,
(I've got the same prob)
What if the hu and amp are solidly grounded to the floor, and the rcas at the hu are connected to ground in the unit. There is going to be a loop (and I can't cut the rca shields either).
Deizenuts101
Deizenuts101
Gardena, CA
jnb
