Engine Noise From Amp?
my factory amp doesnt use rcas, just normal wiring. i looked at the car's manual for the wiring diagram. and there isnt a ground wire either. the bolts that hold it down are probably the grounding points. its just weird that only with aftermarket speakers, i get the static. with the factory speakers its fine.
Probably because the stock speakers are pure shit. I'm assuming you are using the stock speaker wire as well? Stock H/U? Best course of action is to upgrade the speaker wiring and get a decent aftermarket H/U and amp. OEM is crap. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
aardvark
aardvark
Dark smokey cafes of Bolsa, CA
aardvark
Mike Mccabe
