Engine Check Light keeps coming on
Autozone said high voltage is the problem? That hardly makes any sense you should get low voltage if you play your subs for that long.
Autozone said something about high current.
Anyway I checked my voltage:
Does not go below 13 volts. Usually stays at 14.1 or close to 14 volts when at very high volume.
They did, just found it actually.
Two of them:
Troubleshooting N/A
OEM Brand: Honda
Definition
BBElectric load detector (ELD) circuit high input
Probable cause
BB1. - Open or short circuit condition
BB2. - Failed ECM
Definition
BBCatalyst system efficiency below threshold bank 1
Probable cause
BB1. - A/F ratio concert
BB2. - Air leak near H02S
BB3. - Ignition system concern
BB4. - Faulty catalytic converter
No clue what any of these mean. May have to have my mechanic check it out.
Also I've had the engine light come on a few before with same reason as OP. But i can always unhook both batteries and the light would be gone after.....
check your grounds
checked it already, actually the first time my engine light came on was when my rear battery's ground came off //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif while i was driving and playing music.
but everything is fine now, all grounds are good.
checked it already, actually the first time my engine light came on was when my rear battery's ground came off while i was driving and playing music.but everything is fine now, all grounds are good.
how does that just happen? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
plyer3
plyer3
N Little Rock, AR
batmanwb
