endless bass?
could be a rca connection.
bad rca's
just bad connection
rca grounding out
easy test, just unplug rca's turn car on see what happens, then hook your ipod directly to the amp and see what happens. should tell you if its tour rca's or not. also check grounds for sure on amps and your head unit.
so what happens if you never turn it off...
earthquake? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
jk
do you have another head unit to swap in to rule out that being the problem?
its a cvr kicker 12 and a kx 600.1 amp that i installed myself[im very confident its all wired right too]. i did break the tip of the rca cable in the inlet hole that i had to open up the amp and push out a few weeks ago. maybe i did a little damage some how? it seems to be doing it less and less,maybe one out of 20 times i turn it on now but it will probally do it again. is there anything i should check for? also the grounds are good just checked that fully.
yeaaa this would be saying something here i think...
yotabass
yotabass
lanc,pa
yotabass
vegang
vegang
