Enclosure Shape
i've done numerous downfire enclosures for my extended cab. the front angles back same as the seat. looks like a squared darth vader helmet. the only time i noticed a difference is on a really short box and the angled front was almost hitting the magnet of the sub. maybe a 1/2 inch. that box just never sounded right.
i was referencing to ported enclosures.
for instance, one may have a rectangular prism-style enclosure with 3.5 cubes at 32 hZ (slot port).
another guy may have another enclosure that may be fit around and over wheel wells and so forth, but still 3.5 cubes at 32hZ with same port area, etc.
is it going to be adrastic difference?
EDIT: ill post a pic of a design i was thinking about doing. gimme a sec
design:
the entire enclosure is divided, giving each sub 4 cubes with its own port, tuned to 32hZ. as you can see, each side of the enclosure will be mounted on top of a wheel well in an SUV. Dont mind the smaller boxes on either side of the design as they are battery boxes.
bad idea??
i'd bring the outside out a little, keeping your ports and their tuning the same. if you haven't got batteries yet, you could use gell cells and tip that box up on end.
so actually widening the center area, thus aiming the baffles more towards the center, giving the subs more of a mirrored appearance?
dannyz122001
dannyz122001
Baton Rouge,LA
PV Audio
vegang
vegang
