enclosure question (fiberglass)
No Limit
20
Phx
hello i was wondering if it would be easyer to make the molding out of chicken wire or gardeners foam? time isn't an issue its just need to make a good mold (i have to do fiberglass because of how the box is going to be posissioned) I don't want to spend 1300 to get the box built by a perfessional so yea. I have 2 gallons of resin 4 tubes of hardener 27 sq feet of matt... help please LOL!!!!
It really all depends on what you're trying to accomplish. Some people like to use one, some people like to use the other. If you are needing to be able to reshape it easily, then chicken wire would probably work best for you. On the other hand, if you are trying to get really nice smooth, straight lines, then forming the foam in the desired shape will enable you to really fine tune your shape.
I don't know what you are making out of this enclosure. Is this for an amp rack or a sub enclosure or what? If you're making a sub enclosure, you may want to consider making a basic frame or mold out of either mdf or fiberglass, whichever you want, and then using mdf rings and some sort of stretchy material like fleece. If you're going for an amp rack, then you may want to build a box out of mdf with the top side open, then again using fleece or something similar to form the shape.
No Limit
No Limit
Phx
2004alpinewhite
Mike Mccabe
