Enclosure JBL P1022 feedback
Hi,
I want to build a enclosure for a single JBL P1022 sub. I like all kinds of music but especially hiphop. I have run the parameters in WinISD JBL P1022 SPECIFICATIONS Pdf Download. and comes up with the following enclosures (sealed and ported)
Sealed: 45 liters (1,6cu ft) q .7 f3 35hz
Ported: 45 liters port 4" x 27" tuned at 27hz. The port is a bit large but I could fit it with a corner in it.
All net volume. The JBL recommended enclosure doesnt looks too great in winisd, a large bump at 37hz, and lots of port noise.
The ported enclosure looks ok, group delay looks a bit high but that's at 25hz, so I'm not sure if you will notice that. Air velocity should be ok.
Any thoughts? Or should I just stick with the JBL recommended?
I will have 500-600w rms available.
Grey is JBL recommended, Yellow is what I came up with.
Thanks in advance.
Regards Paul
Your graphs don't resemble the JBL graphs because they aren't derived the same way. JBL actually measures the subwoofer outside and inside cars. The in-car predicted response is an average of many vehicles. You're also planning to use more power than what it's rated to handle, and although that in itself is not a big deal, you may want to increase the port area a bit and consider an amplifier with a subsonic filter if yours lacks that feature.
Pauwl
Pauwl
Netherlands, Amsterdam
trumpet
