Enclosure help
[quote name='germanyt']Lots of people build and ship. Does it have to be local? I build but @CSCStang is the man here. Check with him and if he is too busy I'd be happy to help.[/QUOTE]
Outta commission until after surgery actually. Gonna be a few months.
Sent from my SCH-I605 using Tapatalk
I would prefer local unless you have experience with a nissan frontier.Want something custom that goes over the transmission hump and possibly downfiring with a side port
07 king cab. I got about 50 wide and 14 deep.Also need the box angled so the seats go back. Subs are re se10" powered by a slash 1000/1
Gimme a little bit. I think I have a king cab here on the lot i can measure. Ill run an idea by you and see what you think. If youd still rather find something local to you its no big deal but I dont mind working up something for you. Give me the evening and check back.
Will do, thanks
Will do, thanks
This just like yours?
And you want subs down and port and still under the seat?
Looks just like that. I did remove the tool tray. I thought subs down port to side. I ride motocross and would like to have a place to store my gear when it rains. Right now I have subs and port up.Loud as hell and sounds good but no storage and the box I made is not the prettiest. It's not bad but just a plain rectangle box and I got some small 4x4's under the front so it sits tight against the folded up seats. I leave the seats in the up position so the box can lean against them
The two Frontiers I have access to are both crew cab so unfortunately I have nothing to measure. Space will be crucial here. I recently did 2 8s under the seat in a silverado and it was hard to squeeze in the airspace. I know you have some max dimansions in mind but accurate measurements are key when shipping a box. Cant have it get there and not fit. Ill let you know what I find.
psylo535
psylo535
tampa,fl.
Bamacabbie
