Enclosure help on ports.
boomzilla
Got 'Roids?
i just got a design from unrated, but i had a question on tuning the aero ports. from what i understand the more aero ports, the longer they all have to be to reach the desired frequency, but if i used lets say one in a 2.8 cu. ft. box, i wanted to tune low, would i make it shorter? im trying to figure this out on psp's port calculator and just wanted more enlightment.
ill explain my situation: i have a 2.8 cu. ft. box waiting to be built (32'' w, 15'' h, 11 3/4'' d), i wanted a tune to 32-34 because of the loudness, but i noticed in my box now (tuned at around 32), the lows sound like poo. i am messing with psp's port calculator, and figured if i used 2 3'' ports and tried tuning at 30, my length on both increased to 12.92''. which i cant because of the box being 11.75 deep. if i use one 3 inch port, and use the same tuning freq. i get 5.36''. so would one port be better in my situation or would 2 benefit it better?
Tune low as in above 32? Like 40? or like 25? I just put in a 4 inch aero last night in a 2.5-2.6 cubes box and it was 10.5 inches long. 25 would make it longer and 40 hz would make it shorter if that helps.
alright kool, thank you.
does anyone have a list of length to frequency diagrams? thatd be killer to have as a sticky up here since alot of us are getting into aeros now.
use psp's aeroport calculator:
http://www.psp-inc.com/
I have..... read my 1st post over again: i am messing with psp's port calculator, and figured if i used 2 3'' ports and tried tuning at 30, my length on both increased to 12.92''. which i cant because of the box being 11.75 deep. if i use one 3 inch port, and use the same tuning freq. i get 5.36''. so would one port be better in my situation or would 2 benefit it better?
BL 12 – Ported box we recommend using 1.8-2.5 cubic feet @ 30-37Hz (I personally think that a 32hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per cubic foot of volume.
so would i do 12 X 2.8? and thats my port area?
my original box design has 2 3'' aeroports 9 13/16'' long, making a tuning of 34 hz. but what i want to do is change that to 30hz, but i want help to figure it out myself incase i want to change the tuning again.
boomzilla
Got 'Roids?
boomzilla
Florida
boomzilla
