Enclosure design needed please....
I need a design for a pair of T215s(the current model). The box has to go into the trunk of a 2011 Impala. I'm looking for something tuned to 30-40hz. Please help, I have someone willing to cut tomorrow.
ported i assume? what kind of port will you be using? dimensions? shoot me a PM
What do you guys think of these dimensions for this box: Ext H - 17.5", Ext W 39.5", Ext D - 24". 2 ports: 6" diameter x 15" long. What changes would you recommend making? I would like to do a vent port, does anyone have any suggestions on modifying this to a vent port?
The 6" aeros arent enough port im not running the numbers on that box as I have built many impalas you need 2-12's not enought room for 2-15's unless you think you can build it inside the trunk
According to the RF website. I could build two separate boxes that would both fit in the trunk ported. Is it really going to be that much more difficult with two in a box? Building in trunk is possible I suppose, but I think it would be a complete nightmare. I have to double check but I'm 95% sure the 17x39.5x24 will fit in the trunk. Atleast if I go in from the back seat.
You can and will do as you please I just know from personal experience with that car 2-12's is a much much better option. Everyone wants to cram the biggest sub in their vehicle they think they can thats not the best idea when you will start choking the ports off or the subs themselves if you want to get full potential from your system and you want 2-15's then you need to be prepared to build a box inside the trunk that will consume the entire trunk pretty much or wall the vehicle those are the best options if your just dead set on making 15's work in your vehicle.
burgundy
burgundy
TX
dbeez
