Elemental K vs Jl W6
i will probably end up going with the elemental k. should i use a ported or sealed box for best overall performance in a daily driver?
Originally posted by coolman91985 i will probably end up going with the elemental k. should i use a ported or sealed box for best overall performance in a daily driver?
Are you shooting more for sound quality or SPL? Either sealed or ported will work well.
- Steve
Originally posted by coolman91985 i want it to hit as hard as possible. but also sound pretty good.
If you want to hit hard, my suggestion would be ported. It will still sound good.
Either ported or sealed will work well in your application.
How much room do you have for a box?
- Steve
prety much my whole trunk i guess. i have a 98 nissan sentra if that helps. i still want to be able to use my trunk though. its a little bit bigger than a honda civics.
Originally posted by coolman91985 prety much my whole trunk i guess. i have a 98 nissan sentra if that helps. i still want to be able to use my trunk though. its a little bit bigger than a honda civics.
I suggest you take some measurements of the maximum dimensions of your trunk that you want to work with, factor in the space that you still want for access and useage of the trunk.
coolman91985
coolman91985
Dallas
Randy Savage
