Elemental Designs info???
is it just me or does it seem like once you get into "box design" on that page all those things like
How do I know if my speaker is made for a ported or sealed box?
How do I calculate interior volume of a enclosure?
should be links? someone check it out, see if your getting the same thing (or tell me why im being an idiot and cant get into any box design)
That page is always under construction, they keep the things they really need up and running, the the rest of the stuff is always an on going project. Does look like it would be an amazing resource if they could get it all finished. Try out winisd, it'll answer some of yoru questions.
Originally posted by mgaidica thanks, but that doesnt even have ED's on there, and until i can get into the website i cant input that information to the program, but it helps. c'ya.
why cant u get into that site??? since u never stated which sub your talkin about ill assume you mean the k's
Specifications e12K
Qts. .36
Qms. 4.97
Qes. .39
Fs. 24hz
Vas. 83 L
Sensitivity 86.5 dB
Re. 1.75 Per Coil
xMax 15.8 mm
BL Product 20
Sd 490
Magnet Weight 100oz
Displacement .08 CF
Cut - Out Diameter 11 1/8"
High Excursion Back Plate yes
Speaker Weight 18
Mounting Depth 5.9"
Power Handling e12k
Mininum Rec. Power 75 Watts
Rec. RMS Power 400 Watts
Maximum RMS Power 900 Watts
mgaidica
mgaidica
Northville, MI
mgaidica
