Elemental Design 12A.22. Is a Phoenix Gold Tantrum 1200.2 too powerful for it?
Originally posted by BigBoomer Wait a min... ur gettin a prefab box???!?!!//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I bought a sealed box from subzone thats 1.2cu.ft. The ED specs on their site say to use a box that is 1cu.ft. so i figure with the sub volume displacement it will be around 1 cu.ft.
Is there something wrong with using a prefab box?
-Jalal
Originally posted by MJ23FE I bought a sealed box from subzone thats 1.2cu.ft. The ED specs on their site say to use a box that is 1cu.ft. so i figure with the sub volume displacement it will be around 1 cu.ft.
-Jalal
Nothing other than spending 50 buckes on it. Also what impendance is that sub? Sorry I see it is 2 ohms. Why not a jbl 1200.1? You could wire it to 4 ohms for 600 watts. Later on you when you get another you could wire it to 2ohm's and get 1200+//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif. Plus the JBL can be had for 275.
-Jalal
No, there are some that are built out of a 'flimsy' matereal...with that much power you could cause a leak or worse explode(k mabe a lil over exageration(sp?)) just make sure its biuld out of mdf (medium density fiderboard...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Originally posted by BDIDDY Nothing other than spending 50 buckes on it. Also what impendance is that sub? Sorry I see it is 2 ohms. Why not a jbl 1200.1? You could wire it to 4 ohms for 600 watts. Later on you when you get another you could wire it to 2ohm's and get 1200+//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif. Plus the JBL can be had for 275.
meh waste 50 on the box waste 275 on the amp it's all the same:-d.
adam
I think the JBL is way overpriced for this situation then.. I would NEVER run one of those things at 1 ohm. And there are many other amps out there that do much better at 4 ohms. Like the Tantrum. Get that thing, you will be happy. Shop around you can get one for under $300. I did once..
Dave
Originally posted by Primetime I think the JBL is way overpriced for this situation then.. I would NEVER run one of those things at 1 ohm. And there are many other amps out there that do much better at 4 ohms. Like the Tantrum. Get that thing, you will be happy. Shop around you can get one for under $300. I did once..
Dave
300 new? and where?
660
984
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
837
MJ23FE
MJ23FE
Bergen County, NJ
xjmadness
maylar
    Jun 2, 2024
    Jun 1, 2024
