Ehh how do I find subwoofer displacment ?? And measure port ??
dedwardk
So ive done some builds in the past (been a while) and Im very rusty on calculations. I know they have internet calculators (which Ive been using) but it comes down to a few tricky things for me.
Kicker manual says this for max enclosure ...which is what id like to aim for
Code:
Box Volume, ft³ (L) + port                =    5 (142)
Port Opening Size, in x in (cm x cm)   =    3X15.5 (7.6X39.4)
Port Length, in (cm)                        =    22 (55.9)
Power Handling, RMS                       =    900
according to the specs I would want to figure out what the actual port displacement is and subtract that from 5 to get the actual box cubic feet spec ?
And how do I know what the above is tuned at ???
it is 5 ft^3 plus the port and driver .... but that is the max ...depending on how much power you are running could be fine either way...
what sub?power and what are your max dims ...and sub/port orientation?
Code:
use this to figure out what your box is tuned at: Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
box is tuned around 30hz assuming 5 cu/ft is AFTER sub and port displacement. If its 5cu/ft BEFORE sub and port disp, tuning will be higher
what sub is this?
it is 5 ft^3 plus the port and driver .... but that is the max ...depending on how much power you are running could be fine either way...what sub?power and what are your max dims ...and sub/port orientation?
Hey thanks for the help... I was confused on the spec sheet.... says Box + port = 5
Two 15" Kicker CVX
1 Alpine Mono D 1000 rms @ 2
Box = 48" Wide ---- 19"-22" Depth ----- 30"-35" Height
I want to build a slot port with shared port and shared box space ..
here is another question about box.
Obviously if I use both of my subs they wont be getting 1000rms .. so is it pointless to build a box that is for that power ?? would it effect loudness if I shrank the box down to a box that has a max recommended of 500 per sub ??
My gut says stick with large box for loudness and quality ...
You're welcome!!
who called the grammar police ?? I dont care enough to properly word my internet post .. you still knew what I meant //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Im here to build a box not spell properly .. I passed all my English classes already .. when I transfer for my bachelors I be on my tippy toes again
Haha Im here for you man!!
Sounds to me like L7 15" with those measurements
hey see we both made mistakes ... not a L7 .. its a 15"cvx ... and my post wasnt in audio so it couldnt have sounded like an L7 .. unless you read it out loud .. but then you'd still be wrong //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
hey you should quote me and tell me I left out a couple of apostrophes
Two 15" Kicker CVX
When running on low power, its best to go with the absolute biggest box you can fit in because larger boxes are more efficient
what sub is this?
thanks for the reply !! I was already using that exact site .. Problem is it doesnt hint on the calculator page whether you should add to the box for port space .. or just keep same specs and put port inside what you got already .. thats where I was drawing a weird face //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
thanks though
also that would help with port noise theoretically ?? cause when you use smaller box and crank it up it may give a whistle ??
or is that what you meant by efficient //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
sorry guys .. told u im rusty
Missed more than a couple of apostrophes! When I read Kicker I instantly think L7 I forget about the "CVX"
dedwardk
dedwardk
Omaha
dedwardk
