Eh,,, how would I wire this up???
Plottin4success
I just bought a set of PPI 356cs comps and a Sundown SAX125.2 amp and Im waiting on both to come in. The comps are 4ohms. The Sundown does 125x2 @ 4ohm, 200x2 @ 2ohm, and 400x1 bridged @ 4ohm. Maybe I keep over thinking this, but it is confusing the hell out of me. I've wired up my last three systems (sub and amp only) with no problems. So how would I do this? I'll be running passive. I know a few peeps on here are running 200w plus to theirs. Can I wire mine up @ 2 ohms and get 200 to each set? Im lost. What are my options?
ANY help is appreciated
no you can't wire it two ohms the comp set you are getting is 4 ohms so just wire it normal. there's nothing you can do to wire the set you are getting at 2 ohms. besides that you most likely won't hear the 75 watt difference.
the only way you are going to get a 2 ohm load is if you run both speakers off of one channel, which would be stupid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Plottin4success
Plottin4success
In a kitchen, Louisiana
Plottin4success
