efficent 5k
dbjunior
looking into getting a 4-5k amp and want to get the most efficent amp possible looking at mmatts but the hd4000 is the biggest they have and it will be fun trying to get one of those its not listed on the product list. the amp will be run at 2 or .5 ohm
amp cant be rated more than 5k and limited to stock plus 1 800cuin batt so efficency is very important the hd4000 is rated at 79% at full power not 4ohm like most amps
the mmats is with out question the most efficient, but they are not easy to get a hold of, it took me quite a while to get mine.
and they will do more than rated power, i saw one bench test with a dummy 1 ohm load that resulted in 48xx at 13.8. i love mine, a lot of power in a very small package.
just curious how much did the hd4k run you i know if you get it from them you need to be in the lanes so pm what it cost you and if you bought it new or used.
as for the sd5k just not a fan. id like to see a comparison between the mmatts and the d9/atomic 5k or another amp with that board. i know with a heavy electrical the 5ks will make more power but with a single batt in back it might not be much of a difference
dbjunior
dbjunior
ma
dbjunior
