Ed 15a
a few that i know off hand...i have the full spec sheet at home....i'll update the thread later when i get home with the rest of the specs...
Continuous Power Handling: 1000watts
One Way Excursion (XMAX): 29.1mm
FS 28.8hz
Sealed Enclosure Range: 0.75-1.5ft3
Ported ENclosure Range: 1.5-2.5ft3
here's the full list:
nominal diameter: 15" (400mm)
continuous power handling: 1000w
voice coil: 3" diameter, 4-layer, aluminum former
available configurations: dual 2ohm
xmax (one way linear): 29.1mm
sealed enclosure range: 0.75-1.50cu ft
ported enclosure range: 1.5-2.50cu ft
mounting depth: 7.6"
driver frontal diameter: 15.5"
motor diameter: 7.441"
driver weight: 31.74lbs
ts params:
fs-28.8hz
Qe- .37
Qm- 2.74
Qts- .33
Vas- 96.47 Ltr
Sd- 0.0806m^2
Re- 6.77ohm
electro-mechanical params @ x=0
Rms- 19.07ohmm
Sd- 0.0806m^2 effective radius
Bl- 30.96
x parameters from curve fit:
xmag- 30.44mm
xsus- 29.1mm
xmax- 29.1mm
_PuNiShEr_
68 Camaro
_PuNiShEr_
Iowa
chinny
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
