Eclipse / TC Sounds LMS 10" SW8000
ciaonzo
TheContinental
11,703
76
WI
10" Eclipse SW8000 BNIB
This is BNIB but I did remove the logo as I always do with Eclipse drivers. TC9 motor with a big copper shorting ring, and a very lightweight aluminum LMS coil. Sealed enclosures ranging from 1.5-2.25 cu.ft will be best. Thermal is pretty great on these, I watched a video of one seeing wall power for minutes on end. This allows for awesome dynamic capabilities for which I can attest to. I've been thoroughly enjoying one on a USAcoustics 2300F for the past couple years. Makes over 1k @ 4 ohm. This driver will challenge your amplifier so make sure to pair it up with one that is happy to run at 2 ohm all day. It would also be a shame to use this driver with an amplifier that has a subsonic filter. This thing digs down into the teens without any issue. 15-16Hz is insane in my vehicle. Even a SSF that is centered @ 10Hz is aggressively filtering out 19Hz and below.
These are older pics below but I will put some fresh ones up if you prefer. Condition is exactly the same (only selling the driver on the right with the plain cone).
$225 shipped, CONUS.
CONUS only, please.
You wouldn't have this drivers specific T/S parameters?
Sure. I think these numbers were pulled from one that Audio_Phill had. This one could very well have an Re of 3.0, I just spit out 2.8 because most of the LMS drivers are sitting at 2.8.
tsp's from a sw8000
Re = 3.0347 ohms
Fs = 24.4238 Hz
Zmax = 24.9541 ohms
Qes = 0.6189
Qms = 4.4707
Qts = 0.5437
Le = 1.0843 mH (at 1 kHz)
Diam = 209.5500 mm ( 8.2500 in )
Sd =34487.7765 mm^2( 53.4562 in^2)
Vas = 40.6835 L ( 1.4367 ft^3)
BL = 11.5191 N/A
Mms = 176.3554 g
Cms = 240.7817 uM/N
Kms = 4153.1392 N/M
Rms = 6.0535 R mechanical
Efficiency = 0.0900 %
Sensitivity= 81.5596 dB @1W/1m
Would you be willing to sell both? I'm really looking for a nice set of subs to run sealed.
Nah, I'm using the other one. I also planned on using two of them but one was enough. After a demo, the look on people's faces when I show them that I'm running a single sealed 10" is priceless.
How's 600rms at 2 ohm daily sound?
That power is a bit low for shoving this into 1 cube. I'd shoot for between 2-2.5 with that power on this driver.
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
819
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
    May 16, 2024
    May 16, 2024
