Eclipse 8445 Bad Display??
crimson_sky
I have an Eclipse 8445 HU and during the day I can't seem to see anything on the display. Not sure if anyone else who has this problem?? I think it might be a bad display, called Eclipse up and they told me I should be able to see the display and it should be bright. Any help would be grateful.
thanks
I had it installed by the dealer, at night I can see that everything is working. I think the display is just bad. So are you able to see the display during the day? thanks
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I found out what the problem was. The illumination wire was connected to my Ignition wire, it the HU was built so that when the illumination wire (normally connected to the headlamp system) will dim the display. Wow, disconnected the orange/white wire now it all bright. Now just gotta figure out how to connect it to the headlamp system... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I have a 00 honda civic, was thinking of looking under the dashboard and find any wire leading to the headlights. Its a mess under there with all the wiring I have for my alarm :S Dunno how i'm gonna do this
I have the unit also and the head unit display is not visable during the day. I have a convertible. I wonder If the wiring is correct. Why not leave the orange/white disconnected? It would be at full brightness all the time.
No, if you disconnect it all the time only the two knobs will light up, all the other buttons will be off. When the illumination wire is wired correctly to the headlights, when you turn on headlights, the display will dim and all the buttons will light up.
Hmm wow I didn't know that..... looks like I'm going to have to spend some time and fix the wiring on my head unit then //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
crimson_sky
crimson_sky
Windsor,canada
MegaHurtz
