eclipse 8443 HPF???
  • 2
Yes I do. I have the 8053 which is the same deck except mine has balanced out and yours is 8v. 1st thing 1st when you yurn the deck on hold the volume knobdown untill it say's "loud off" then press sound and hold it untill it say's "pro mode on" now tap the sound button untill you get to the X-over. now press the right knob 2 times or untill you get to the part of the mid/low (which unless you are runnig a 3 way system it will act as your x-over for all speakers except your subs) turn the knobto change the x-over point(I selected 80) and the up & down buttons on the right to select the curve you want to x-over at(I selected 24oct) I hope that made sense.
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
7
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
4
881
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
datguyclark
datguyclark
florida
datguyclark
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
