Eclipse 34230 Premium (big clean two channel power)
Spooney
Amp is in beautiful physical shape and 100 percent functional. May have a scratch here and there but overall it is a very nice looking amp. The worst of the scratches are right on the side of the heatsink next to the mounting holes but the rest of the amp is so nice you may not even notice. Big clean 2 channel power for a monster front stage or even low powered subwoofer duty. Couple weird things about this amp.......It does not have a highpass crossover for the output channels.Only a lowpass filter and subsonic filter. It does however have highpass preamp outputs with variable crossover frequency or you can defeat the crossover on the preamp outputs altogether. The other little quirk about this bad boy is that it is NOT bridgeable(not broken it simply is not capable of being bridged) and is only listed as stable into 4 ohms stereo although I have heard and read of people running these at 2 ohms no problems. If you look at the guts you will know this amp means business.
Link to the owners manual here : http://www.cartoys.com/cartoy/pdfs/eclipse_amp_manual.pdf
Specs Here:
Specs.....
Max. Power Output
550W x 2ch (4 Ohms.)
Power Output (4 Ohms)
370W x 2ch THD @ Rated Power @ 4 0.004%
Signal to Noise 105dB
Freq. Response
+0, –0.7
Crosstalk
–75dB
Slew Rate
10Vオs
Damping Factor @ 60Hz
>200
Input Sensitivity
0.2 ~ 8V
Max. Current Consumption (4 ohms)
100 amps
CHANNELFLEX CROSSOVER
Low Pass 12dB/octave
50 ~ 200Hz
Pre-Out Crossover High Pass 12dB/octave
50 ~ 200Hz —
Subsonic Filter Freq. Range
0-60Hz 18dB/octave
Dimensions (W x H x D) 18.80½ x 2.05½ x 11.85½
Designed, engineered and made in the U.S.A.
200 shipped OBO in the good ol USA . Please PM with any interest or questions.. Much easier to track and almost a guarantee that I will get back to you quickly
Included in price
She is a great amp but physically too big to use in my install. I'd like to use her in my car but it just won't work . Great clean two channel power. Would also consider trades for a battery,sundown sa-12,skar vvx12,OA 12, or similar sub, or deadener. Cash offers considered as well.
Wish I had the money, would love to power a pair of 8's in my doors with it.
******* Bobb the da7232 was the biggest 2 channel amp eclipse made(I have 2).
Bump for offers of cash or car audio related trades. Looking for deadener, distro blocks, 10,12, or 15 inch subs in the power and quality range of a sundown SA series/skarr vvx etc or a decent set of components
Spooney
Spooney
Charlotte,MI,USA
GAMEOVERCCA
