ebay mmats amp for 550.00 NEW
It doesnt matter if the system is on or not. If they are Dual 2 then they will either be a .5, or a 2 ohm load if you wire the pair together. The only time you will see a 1 ohm load is if each speaker is seperate, and parallel. Then you will see 2 1 ohm loads. If they are dual 2 you should look for an amp that is .5 ohm stable, so you can wire both subs in parallel. And yes 2100 watts would be over powering them, but if the signal is a clean one they should be able to handle them with properly set gains.
ok, cool,
But to get a better idea....
Im sitting at a half of an ohm ur saying??
I have both speakers red coil conections running together straight to the amp, same as the neg coil wires too. So i have all red to red and black to black !!
When joining these speakers wiring where is my ohm load sitting?
And is the amp bringing the load down when i connect it as well, im understanding that the amp brings the load level down again inside?
ok your subs are dual 2 so to get a .5 ohm load you would take one sub and wire + and + together to get one positive wire then you would wire - and - together to get one negative wire. Now get sub is wired to 1 ohm.The mmats amp is a mono channel amp with two + and - connectors but its still only a one channel amp there is just two + and - 's to make connection easier.So now take one sub wire it to one set of + and - and take the other sub and wire it to the other + and - .Now you have a .5 ohm load.
LOUD 4DOOR
LOUD 4DOOR
BALTIMORE
casper97ta
