baseballer1100
My life be like....
- Thread Starter
- #16
Does this work pretty well? how straight are the cuts?this is how I cut two full 4 foot X 8foot, 16mm thick sheets at once...
Depends on your skill with a circular saw.Does this work pretty well? how straight are the cuts?
Used this today Glorious!!! Sweet cut except i ****ed it up with the jigsaw...But thankls for the ideathis is how I cut two full 4 foot X 8foot, 16mm thick sheets at once...
The table saw gets used everyday.I already have one tried to get pics its really nice long enough to fit a 4x8 piece...But i couldnt forgot to charge the battery..How often do you use your table saw? If you use it fairly often, it may not be a bad idea to build a larger wood table around the saw. Extened it out to the side opposite your fence. And extend it farther out the back. Ill try to get you a pic of mine. This allows be to cut a full sheet easily with no need for help. IT something fairly cheap to build also. Mine is just 2 sheets of particle board and some 2x4's.
That wouldnt be too bad.aww dont worry, my avatar is one of my only friends too:yumyum:
Not big enoughyou can also buy the pre-cut ones. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifthere 24"x48". they have plywood, mdf and birch.
PowerNaudio is a god. Pics to come soon enough... THis qupte thing is really nice.i use the same technic as Death By Bass and it works almost perfect if not perfect. just make sure you align the fence just right, so take your time aligning it till you get used to it.
That's how my uncle's do it, and they always get my cuts straights.i use the same technic as Death By Bass and it works almost perfect if not perfect. just make sure you align the fence just right, so take your time aligning it till you get used to it.
I would say it doesnt matter as long as the cuts are straight?I'm a newbie when it comes to the circular saw.
Is the guide supposed to be on the right side of the cut or the left side?
I've been putting it on the left of my cut.
yeah, doens't matter... you may not always be able to do it the way I did, as the motor on the saw may be in the way...I'm a newbie when it comes to the circular saw.
edit: everyone loves me!!!! hahaha!!!
