Dynamat, second skin, brown bread, .....
They are all good...and they will all work.
Dynamat is too expensive.
Brown Bead and Second Skin are cheaper and work really well.
Dont forget eDead...which works wonders as well.
They all work, so get whatever's cheapest. Second Skin and eDead dont really smell at that bad, though.
- Steve
Originally posted by teg_racer arent they all the same? just with different names on them... couldnt u just go out to home depot and pick up so sticky insulator and it would work the same?
That's what I initially thought until I tired some cheap bulk damping mats and I became a believer.
I guess it's the contents of the black stuff, the adhesive and thickness. Also, you can make a thinner damper work better than more expensive thicker dmaping mats, if you install it correct. Again, it's all install. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by paikiah That's what I initially thought until I tired some cheap bulk damping mats and I became a believer.
i have found one brand of home improvemnt brand black sticky stuff that works perfectly...its exactly the same thickness as dynamat extreme and sticks just as good...i put it on my car in 2000 and it is still on perfectly and works great, you just gotta look around and find some good stuff....
Originally posted by EPanther99 i have found one brand of home improvemnt brand black sticky stuff that works perfectly...its exactly the same thickness as dynamat extreme and sticks just as good...i put it on my car in 2000 and it is still on perfectly and works great, you just gotta look around and find some good stuff....
how's the odour on those things? Do you have to air your car for a few days, or were you lucky enough to find stuff that doesn't emit any odours?
I know water-proofing or something that some people tried a few months back emitted a really bad toxic smell. Just be careful with toxic fumes man. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by paikiah how's the odour on those things? Do you have to air your car for a few days, or were you lucky enough to find stuff that doesn't emit any odours?
thats what i had heard from a lot of people about the horrible odor, but i gues si was just lucky, bc the stuff i used had no odor at all, like nothing, i actually have half the roll sitting right here in my closet, you could stick your nose on it and not smell a thing, i have actually installed it on maybe 10 or 15 cars ranging from hondas and mustangs to f-150s and rangers and no one has ever said anything abut any smell.
I prefer Brown Bread. Easiest and best stuff I have worked with to date, and that includes Dynamat Orig, Dynamat Extreme, B-Quiet Lite, B-Quiet Extreme, Iko Goldshield, and probably another one or two.
what is the stuff u use called and where did u get it? sounds like its good.
Originally posted by teg_racer what is the stuff u use called and where did u get it? sounds like its good.
i know i got it at lowes, its called metal ice flashing i think its been about 8 or 9 months since i have bought any....ill ave to go back and let you know the specifics.....ill be able to tell you exactly where it is in the store so if you have al owes near you it should be in about the same spot.
Does anyone hgave expereience with fatmat and raamat. I have one layer of dynamat extreme in my trunk and cant afford there prices anymore since i need alot.
smokeoff
here's my 3 cents
smokeoff
Cambria,WI
ifandorbuts
