DVC Wiring Question
Wire them series/ parallel for a 4 ohm load and run the Pioneer bridged. I had it set up for years like that with no issues. Just keep your gains down with those subs.
The *best* way to drive VCs from separate channels is to do a mono mix of the signals before the amp so that both amp channels have exactly the same signal on them.
However...
You will not damage a DVC sub by running the VCs off different channels. Even if the channels aren't well matched. Matching the gains is just to make sure you get as much in-phase power as possible into the sub for max efficiency. You can actually drive the VCs with completely different signals and not damage the sub at all.
lovecat48519
lovecat48519
Berrien Springs, MI
Jepalan
vegang
vegang
