Duralast Gold Battery
My setup is a Sundown 1500d and 2 12" DD 3500's... Big three is done with 1/0 knukoncepts...Stock alternator.. 1/0 knu power wire... I think i might go with that duralast gold... anyone think it wont work???
i have this sam battery cause mine died and i had to get a replacement but i didnt have the money for the dekas i want. i see bad voltage drop with this battery and my big three is done and a stock 105 amp alt. im only running 100o watts rms at the moment so i wouldnt recomend this battery for the price. for 75 bucks more you can get a intimadator 9a31 which i plan on getting two of soon because im upgrading amps/ subs soon. idk tho for the money i dont think this is worth it
do U have a battery for this price that has top posts and side mounts that will fit in my stock battery box for the same price or less??? max dims are 11x7x8??? LEt me know what kind and where i can get it... Thanks
I have top post only but it will definately fit, you can buy a side post convertor for them as well or make 1 from a piece of copper or brass. or just use a standard 6mm bolt and ring terminals. the dimensions are :
Weight: 25 lb
Cranking Amps:950
Amp hours: 35
it is stronger and better than 2 of the duralast or red/yellow top batts for car audio. they recharge 10x's faster and last alot longer. they are 130 shipped pm for info.
Isaac_62
Isaac_62
Michigan
smoka
vegang
vegang
