Duralast Gold Battery
If u read the specs it gives on the link i provided... It states "absorbed glass matt".. Im not saying its a good bat.. i just dont want to monkey around with top post adapters and such that i would have to on a car audio bat. per say. Also the Ah rating on the die hard is higher than the bat u recommended for me... I thought the Ah rating was what mattered when it came to a good car audio battery... Im not set on the die hard yet... but it has an awesome warranty, and its a direct fit... whts the warranty on ur battery?
ive had my duralast battery since i got the car, ive put MANY cycles of being dead on it and it still holds up fantastic.......powering my stuff good for a long while now, dont see how its not killed yet, and ive had the car for a year, that battery is prolly older, i have a soundstream 1700d powering a sundown nightshade 18 and a sundown sax125.2 powering my dorr speakers and its still doin great.
I have top post only but it will definately fit, you can buy a side post convertor for them as well or make 1 from a piece of copper or brass. or just use a standard 6mm bolt and ring terminals. the dimensions are :
Weight: 25 lb
Cranking Amps:950
Amp hours: 35
it is stronger and better than 2 of the duralast or red/yellow top batts for car audio. they recharge 10x's faster and last alot longer. they are 130 shipped pm for info.
You did not specify a brand?
Isaac_62
Isaac_62
Michigan
smoka
Mike Mccabe
