Dual Voice Coil subwoofer not reading same ohms at coils
Humpty
I could smell and bad smell coming frommy sub last night.
So I pulled it out and visually inspected it, it seemed fine. So i pulledout the DMM
and tested the voice coils. Coil 1 read 4 ohms and coil 2 read 2.5 ohms.
DOes this mean the coil is damaged? Will this sub still be usuable?
When they are wire together I get 1.7 ohms and my amp wants 2ohms, will this be okay?
or will the one coil with the lower ohms take more power and end up blowing?
I bet you can answer this question yourself, can't you.
You were clipping your amp and have damaged 1 of your coils.
What amp were you using, what is your setup for your power and ground wires.
How do you have the gain set?
Do you have bass boost set on the amp or head unit?
*hangs heads*
Yes!
I was using mrp-m2000 with a 0gauge stinger wire. Also have a 320a alt with big 3 in o gauge.
gain is at about 30% of the dial, not set with a dmm ( i know i got impatient and f'd up) and bass boost is about 4db or so.
the hu volume was about 35 out of 50, the sub level on the hu is at 8 of 10. thats not the same as bass boost tho is it? All other settings have the deck were not set yet.
Basically I just wanted to know if the sub is garbage or not?
You may be able to use the sub for a bit but it is not really worth it, I have heard of a few times where a shorted out VC has caused damage to the amp.
You do not need any bass boost set on the amp at all.
Humpty
Humpty
Calgary
JoeK
