Dual MTX TS55 10's Ported to 33Hz
jake21
Lifted > Lowered
Ok im building this box for my cousin. He just got two MTX TS55 10's for christmas.
The box is 2.5 cft tuned to 33hz
Here is the build:
MDF cut out to proper measuerments for the entire box
Starting to assemble
Cutting out the sub baffle, I also router'd the edge of the baffle to flow into the port, (what a nice work area.....)
Adding the port
And the top
A little paint for the port, and now all i need is some carpet to finish it off.
Thanks,
Jake
Ok im building this box for my cousin. He just got two MTX TS55 10's for christmas.The box is 2.5 cft tuned to 33hz
Here is the build:
Thanks,
Jake
Have that same table in the frat house. Though admittedly yours is in much better shape, what with its 4 legs and all.
Looks good, why did you recess the port?
just felt like it would be an interesting design
lol it was my parents old kitchen table then they bought a new one and there it is.... in my garage
won't the "recessed" port chanmge tuning atleast a little bit.
a little but nothing too out of proportion
^^^prolly not much at the most 2-3hz's
yea if that...
the tuning wont be changed really at all if it is at correct length. Now if it is 3/4" shorter because he decided to recess the port and not add to the back of the port then I can see the tuning changing...
Yea the tuning might change by half a hz if that.
//content.invisioncic.com/y282845/emoticons/beatdeadhorse5.gif.5d70132dea1eb89b73bf2fdbb6027dd6.gif
i have no idea why i posted that
171
870
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
848
956
jake21
Lifted > Lowered
jake21
Bozeman, MT
Jade_inc
audiobaun
    May 19, 2024
    May 19, 2024
