dual fuse ground
isakdaking
i just got myself a new dual fuse distributor with bigger fuses 150 because i was popping my old fuse wich was only 80. i was wondering if i have to ground it . and where on the fuse distributor can i ground it does it matter where i put the wire . thanks fo ranswering my ground wire question. as for the farade capacitor i just want to knwo hwo to wire it . i have one idmax 12in one 1600 brutus hifonics amp. alpine hu
if your asking if you need to ground your distro block the answer is no... but im too tired to decode that post of yours to help any further at this moment.
thanks for the reply so i dotn need to ground it .. sooo sorry im a newbee the farade capacitor part im still tryign to figure it out oo just let me knwo how to wire one
i just got myself a new dual fuse distributor with bigger fuses 150 because i was popping my old fuse wich was only 80. i was wondering if i have to ground it . and where on the fuse distributor can i ground it does it matter where i put the wire . next question my farade capacitor wires just wondering if ti was right the way the shop did it for me. the ground goes in one way the power comes from the the the small fuse distributor wich had 3 out lets and two on the side the other wire from the fatrade capacitor went to the side of the distributor does nto go directly to the amp . if this is wrong let me know and hows the right way. thank you need .help soon . //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif my system used to work but havnt used it in 6 month due to jbl amp fryign my faul. sub never reached its potential due to small fuses //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
read your posts....can YOU even understand what your saying? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
//content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif
don't tell him to get rid of the cap if you don't know what your talking about. Yes in most installs caps are useless but if installed correctly they can be beneficial. If you don't know 100% of his system specs then don't give him advice like that. If he has a powerful electrical system to back that cap then yeah, it can help.
197
512
957
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
905
isakdaking
isakdaking
brawley ca
connersdad19
