Dual DA1504D
evilmonstertruk
Premium Member
Premium Member
I just bought one of these. The deal I got on it made it a no brainer. I know it's Dual but I just had to know. They have that DA8001 that supposed to do 2500 at 1ohm.
When I get it I'll but up pics and guts. Then try to find some time to install. So we will see.
Description
250 Watts x 4 RMS power @ 4 Ohms
480 Watts x 4 RMS power @ 2 Ohms
900 x 2 RMS @ 4 OHMS (bridged)
3000 Watts Peak Power
Fuses:*
Class D digital
Variable low-pass crossover
Variable subsonic filter
Variable bass boost
High level inputs with auto turn-on
Low-level inputs
Remote bass control included
Dimensions (HXWXL): 1.6" x 4.7" x 10-1/4"
Sent from my Nexus 6 using Tapatalk
Well, they're either redefining the use of fuse protection, or those amps are significantly over-rated.
The 8001 is fused like a ~1500w amp and the 1504 like a 800-1000w amp.
The 1504 should be comparable to PPI's 900.4. If you got it for $125-150 it's probably a good buy as long as it lasts a while. Beyond that there are other options with a track record.
evilmonstertruk
Premium Member
Premium Member
evilmonstertruk
Maryland
n2audio
BP1Fanatic
BP1Fanatic
